Previous in Forum: Properties of Alloy Zinc   Next in Forum: Energy Released in Combustion
Liquid Argon Conversion
12/06/2012 12:23 AM
Dear Sir please explain me 6kl liquid argon is equal to how much compressed gas
Re: Conversion
12/06/2012 12:41 AM
Which temperature and pressure are you referring too? What container into which environment?
What does kl as a unit stand for? Is it kilo liter??
More input needed.
Re: Conversion
12/06/2012 4:01 AM
O-level Chemistry: "A gram-mole of gas occupies 22.4 litres at Standard Temperature and Pressure". The rest is arithmetic.
Anonymous Poster #2
Re: Conversion
12/06/2012 5:11 AM
WAG: 6Ml.
Good Answers: 137
Re: Conversion
12/06/2012 6:20 AM
Are you the OP?
If so, do you really mean 6 megalitre? That's a lot of liquid argon. Or 6 milliltre?
You need to find the density of liquid argon. I don't know offhand but I'd be surprised if it's much different from water so if you just want a rough estimate use 1000kg/m3. That gives you the mass, then use #2 to work out volume of gas at the temperature and pressure.
Anonymous Poster #2
Re: Conversion
12/06/2012 6:26 AM
No, the liquid argon is 6Kl. The OP asked for the amount of gas. For water, the factor is ~1600:1, for ammonia ~600:1; so I "interpolated."
ξ
Re: Conversion
12/06/2012 6:44 AM
Good Answers: 137
Re: Conversion
12/06/2012 7:04 AM
Yes I know the question is about liquid. That's why I said "it's a lot of liquid argon". But what does the OP mean by kl? What did you mean by WAG: 6Ml in #3?
Also the factors you quote depend on the temp and pressure of the gas.
Register to Reply 7 comments
Anonymous Poster (3); Codemaster (2); PWSlack (1); truth is not a compromise (1)
