Previous in Forum: COP> 1? Fact or Fiction?   Next in Forum: Book Publication
Amcor Aircon Unit XF-9
12/07/2012 3:39 AM
Hello,
I have an Amcor Aircon unit XF-9 which worked fine in summer. Now, I would like to use it as a heater only but nothing happens when I set it to heat.
Is this unit a cooling unit only?
I tried to find the manual on the web without any luck. Could someone please point me in the right direction?
Thank you for your help, Jurgen
Pathfinder Tags: Amcor Aircon XF-9
Re: Amcor Aircon unit XF-9
12/07/2012 3:44 AM
228 hits. There must be someone there that will answer a telephone, perhaps?
12/07/2012 4:38 AM
Support
Europe
Kurhausstrasse 82, Zurich 8032, Switzerland
amcoreu@amcorstyle.com
Re: Amcor Aircon Unit XF-9
12/08/2012 1:43 AM
If it is a heat pump during winter it works in heating mode. If it is only an air conditioner you can check whether any strip heaters are provided. In that cast it will provide sensible heating. You need to check the supplier manual.
Good Answers: 102
12/09/2012 12:26 AM
Open it up to see if there any solenoid valves in the refrigerant circuit.
If there are none then it is not reverse cycle capable. Live with that.
If there are some then check the wiring at least or take it to a refrig mechanic to get it sorted.
Register to Reply 4 comments
mrswamy (1); PWSlack (1); Randall (1); Wal (1)
