Previous in Forum: Need Help with MPLAB and Proteus   Next in Forum: Unauthorized Screen Modification
PC Problem
12/09/2012 10:15 AM
windows 7 ultimate stuck in safe mode
Re: pc problem
12/09/2012 10:22 AM
Does the screen give you any options?
Never had this problem, myself.
Did the battery run out of power before the PC shut down?
Re: pc problem
12/09/2012 11:10 AM
At least it is not a blue screen.
You may have a hardware failure or a full hard drive.
You should be able to undo the last thing you did to this machine by restoring to the last good state.
Have you considered LINUX?
Re: PC Problem
12/09/2012 5:23 PM
You should have a boot option before going into safe mode, and then as others have said do a system restore. Win 7 has been the best version of Windows for me to date. If it only boots into safe mode, than I suspect a hardware issue. More info would help here, when did it happen? What were you doing, installing, changing? Laptop, desktop, tablet? Factory installed or OEM? If factory installed, have you called them?
Re: PC Problem
12/10/2012 3:35 AM
Shop fix pay.
Register to Reply 4 comments
JPool (1); lyn (1); PWSlack (1); redfred (1)
