Usually the equipment mfr will provide you with test values. But in GENERAL, remove the gate leads and check the resistance across the gate circuits, it's best to do it with the leads still attached to the SCR (if applicable). It should read between 5 and 90 ohms, less than 5 or greater than 90 and it's no good.
