Previous in Forum: Best Submarine Technology   Next in Forum: 2003 Cavalier 2.2 Leter Ecotech
Best Shear for Superalloy Foils
12/12/2012 11:01 AM
We want to buy a shear for cutting very thin (0.001-0.010 inch, occasionally thicker if possible) sheet metal with the least possible burr. The shear should be able to cut an 8 ft sheet lengthwise, and be electrically powered, either 220 or 480V 3Ø. An automatic feed for cutting multiple strips of the same width would be desirable, but not necessarily a requirement. We will be cutting alloys like Inconel, Stainless Steel, and possibly amorphous brazing foil, as well as softer materials like copper.
What type and brand of shear has proven most reliable for such service?
Good Answers: 153
Re: Best Shear for Superalloy Foils
12/13/2012 5:22 AM
"Least possible burr" cutting several different soft to medium hard materials between 1-3 and 1-2 inch thick an over 8 feet length.
I would have no reservations suggesting laser cutting unless your quantities are exceptionally large. At these thicknesses your speed limitation, even with a low powered laser, is likely to be the carriage speed rather than the actual cutting speed.
For high quantities, slitting straight from the roll, and then cropping to length, offers a better option that shearing.
12/14/2012 10:33 PM
or a plama arc.
Good Answers: 34
Re: Best Shear for Super-alloy Foils
12/15/2012 5:19 AM
There are 263 companies listed on 'Globalspec', manufacturing shearing machines. You may find one of their products a suitable buy.
Shearing machines for superalloy foils
12/15/2012 12:11 PM
Thanks.
I did try to search Globalspec before asking the question, but I searched for 'Shears', not 'Shearing Machines', and may well have not done that in an appropriate place or manner...
I will try to continue your search, but still I was hoping to find someone with experience, good or bad, in shearing these thin materials. We've been doing it for many years with a hand shear, but only for pieces under a foot and a half wide. Now we need to be able to shear at least 8 feet straight cut.
There do exist some machines that roll a wedge wheel past the main cutting edge. I presume that such a machine would be slower than a standard 2-blade shear, but the ease of replacing that wheel to keep it sharp might make it a good choice. We are more interested in precision than in speed at this time.
Of course there may be other types of machines with which I'm not familiar. If so, I'm open to suggestions.
Responding to the other posts: We have tried laser cutting, some years back, but the process left a tiny bead of previously molten material along the bottom edges, which made it unusable for our purpose. It is quite possible that the process has been improved since then. I had not considered plasma for such thin material. We do commonly use waterjet for curved cuts, and it does have the advantage of being able to cut several sheets simultaneously, but it does not have the precision of a shear for straight cuts, and does leave some embedded particles of garnet or other cutting media in the cuts. The contamination can cause problems during welding or brazing.
12/15/2012 12:49 PM
I did try continuing your search, and several searches of my own, but as soon as I put in the 96" length or longer specification, the list is down to one supplier and 6 machines. 4 of those machines are CNC, which we don't need and can't justify. There is no image for the other two, so I have no idea what those machines are like.
Adding the terms 'superalloy foils' to the search only adds suppliers of foils and related stuff, not shears..
dkwarner (2); durtieduck (1); jhhassociates (1); Joshi (1)
