Previous in Forum: Need 1-2 PSI Check Valve Made of LDPE   Next in Forum: How to Put On Body Weight
8 comments
Venturi Design Required
12/14/2012 1:08 AM
hello
for one of my life science project am need to design a venturi to genrate the 500-600mmhg of vaccum in 3 sec.
i/p pressure is 40-50 psi and flow used is 400lpm
the drill size am using for inlet to suction is 0.9mm and exhasut is 1.5mm and for suction is 1.5mm,
from these parameter now i am getting 300mmhg of flow.
could you please suugest what i need to do got the 600mmhg of vaccum.
thanks
sandeep
Pathfinder Tags: venturi vaccum
Good Answers: 21
Re: Venturi design required
12/14/2012 1:59 AM
Just do a internet search for Venturi calculations and there are several options for you.
12/14/2012 3:47 AM
Increase the pressure, or flow, or both.
Re: Venturi Design Required
12/14/2012 8:16 AM
extrude honing after drilling
12/14/2012 8:35 AM
Search CR4, I think we coverd it.
12/15/2012 2:25 AM
This is your project. Do you really think it ethical to ask for someone else to solve the problem for you. Maybe you should buckle down and study the subject matter a little closer. We are not here to do your homework for you. Students are there to learn not to figure out how to get someone else to do their work.
Life is an adventure. Take part in the adventure and you will end up being smarter and better.
A hand without an arm is a useless tool
12/15/2012 3:03 AM
Thank you mr. Jay Really thanks for your advice.i will use this through out my life. I am just require any idea or any experiance to get the job done. I think this is a learning which will increase a much u spend. But once again thanks for ur lesson
Good Answers: 34
12/15/2012 4:10 AM
Designing a venturi to generate 500-600 mm Hg of vacuum in 3 sec
Now be good & research the relevant links above, to find your answer. Good luck.
12/15/2012 8:41 AM
I may not understand the outcome of what your trying to do.
I think that in any Ventura's aspects are in my option is this, The larger intake with some distances from the vacuum side of the vortex should be what is needed. Also
the 0.9 should be 1.5 and exhaust should be 2.5 suction should be larger than that of intake this should be what is needed for vacuum you need.
I hope this is helpful.
Renewable energy Researcher/Inventor
Register to Reply 8 comments
Byron Jay (1); fixitorelse (1); Fredski (1); Joshi (1); kennynabb6 (1); lyn (1); phoenix911 (1); sandeepmech (1)
