Previous in Forum: How Many Support Posts Do I Need, and Where for My Support Beam Load?   Next in Forum: Why Spinning Rugby Ball Improves Distance and Accuracy ?
13 comments
Kiln Alignment
12/14/2012 9:58 AM
good morning
kindly we need your advice cocerneing the insturments which use for cement kiln alignment (types , training , prices ) any addition information . we are planning to do alignment to the kiln by our own technical staff
thank you for your expected reply
Re: Kiln Alignment
12/14/2012 11:10 AM
What type of alignment and resolution do you need? Any pertinent information you provide us will allow us to help you with the instrumentation. A few possible measurements that comes to my electrical engineering mind about a cement kiln are:
  • Temperature uniformity
  • Bearing spatial alignment
  • Flame spatial alignment
  • Sample measurement processes
Your best bet for answering your question though is to consult with the firm that installed the kiln. If you do not understand what they tell you then we at CR4 will gladly explain what they tell you and possibly give you alternatives.
Re: Kiln Alignment
12/14/2012 1:05 PM
good afternoon
thank you for quick answer
what i mean kiln tube 70 mt length with all accsessories like tyres, rollers, shell itself
,concret foundation . how to check the alignment and the settelment and by which types of instruments , correction if the case is needed , training ,cost of all these activites
best regards
Re: Kiln Alignment
12/14/2012 1:52 PM
Hire an outside expert to perform the task this time, and watch them and take photographs and notes as to what they do and the equipment they use.
Then, you'll have a properly installed tube as well as a rough idea of how to do it and the equipment required.
Re: Kiln Alignment
12/14/2012 2:17 PM
good day
thank you for your kind advicement , i will try to lookfor at other web,to get somthing may help , again i appricaite your considering my letter
best regards
Good Answers: 21
Re: Kiln Alignment
12/14/2012 10:51 PM
Music wire, transit, tape measure, very good level. 4 years apprenticeship training to be Millwright.
Hire proper personal with experience in this area.
Good Answers: 34
Re: Kiln Alignment
12/15/2012 3:42 AM
Re: Kiln Alignment
12/20/2012 5:24 AM
good day sir
i follow both links they are very useful especially link no.1
i am so appreciate your help , thank you very much
Location: Base in Madrid, Spain. Updated location every several months.
Re: Kiln Alignment
12/15/2012 4:58 AM
Please read carefully this link:
http://www.tappi.org/Downloads/Conference-Papers/2008/08EPE/08epe81.aspx
Not as a manual of how to do it, but only to have a general idea of the main points to consider before get into something too big (and expensive) to allow chances to fail.
This pic is a hint. You should know what I am referring to.
I strongly endorse Lyn´s advice this time.
Everyday learning.
Re: Kiln Alignment
12/20/2012 5:45 AM
good afternoon
i am so happy because getting alot of good friends within one week
and you are one of them,i printted the file i will read carefully and contact you again
if there is something not clear
thankyou friend
Re: Kiln Alignment
12/17/2012 1:17 AM
hi,
I am currently working in cement plant in the philippines, and we will perform kiln alignment in our own kiln.. I suggest that you will do kiln run out test to check the kiln's ovality and light beam kiln centerline alignment method,,,
these two methods do the tricks in alignment our kiln...
arang na gwapa sa surigao
Re: Kiln Alignment
12/20/2012 11:11 AM
my dear
generally i check the ovality by migration measuring, but to perform light beam test the kiln shell should be without bricks isn't it, and doing it only at new errection ,but our kiln old one . if i have missunderstanding, please kindly inform me
best wishes
Re: Kiln Alignment
12/21/2012 2:00 AM
hi,
you can use light beam alignment even if your kiln is old, infact our kiln is already 40 years old, and every time it bent, we will correct it and align it by means of light beam alignment..
i will send you the diagram on how to use this method
mike
Re: Kiln Alignment
12/21/2012 2:34 AM
good moorning
thank you for taking my letter into consideration .
i'm waiting your next letter .
good luck
Register to Reply 13 comments
abelmh (1); fixitorelse (1); jamals (6); Joshi (1); lyn (1); redfred (1); Russian_1979 (2)
