Previous in Forum: Kiln Alignment   Next in Forum: Bolt Torque
9 comments
Why Spinning Rugby Ball Improves Distance and Accuracy ?
12/14/2012 12:07 PM
1.may be because of gyroscopic effect the projectile will be accurate as tumbling is reduced eventually travelling a little bit longer but i want to be educated with the boundary layer conditions and frictional forces acting on it. 2. can we consider spinning ball as rolling friction between air and ball?
Re: Why spinning rugby ball improves distance and accuracy ?
12/14/2012 12:29 PM
This sounds like homework.
Where have you looked for the answer, so far?
12/16/2012 12:23 AM
homework !! no.. i was expressing my doubt.
i didn't find any boundary layer study on spinning rugby ball...
while basics of friction says for rolling friction, area of contact is less than static so i doubt if this apply on spinning rugby ball as the ball is completely submerged in a fluid(air) so the area of contact is same for both static and spinning.
only fluid dynamics specialist could understand what my doubt is about actually...
12/16/2012 8:52 PM
Touche, Lyn!
only fluid dynamics specialist could understand what my doubt is ..
LOL, you have to grow a fluid dynamic skin. (I thought you had that already!)
Good Answers: 145
12/14/2012 3:01 PM
This does look like homework.
I bet if every search you do is doubled you will get more useful hits. "Rugby Ball" might be what you are interested in but I suspect that "Baseball" will yield more hits and most will contain information useful for rugby.
There has been a lot of information published for baseballs. "Golf ball", "tennis ball" and "football" would also be useful since the spin can have a dramatic effect on how they fly.
When you can't find what you are looking for sometimes it is useful to look in a carefully selected wrong place.
12/16/2012 12:40 AM
ya.. i'll tell you why i'm specific about rugby ball, in the subject of fluid dynamics the shape of the body is very crucial to determine its behaviour or performance.
and the direction of spin do matters for rugby ball but not on spherical ball(very less) ...
aerodynamics of baseball,tennis ball, golf ball, football are of same class and have no match with rugby ball,bullet,missile etc
12/14/2012 4:23 PM
try this:
http://physics.fullerton.edu/~heidi/PROJECTS/football.pdf
Engineering Fields - Mechanical Engineering - New Member Kenya - Member - New Member
Re: Why Spinning Rugby Ball Improves Distance and Accuracy ?
12/15/2012 7:44 AM
What about coriolis?
Technology solves problems we didn't know existed, or didn't realise that they needed to be solved. Tinkering is therefore never pointless.
12/15/2012 1:08 PM
How about boundary layer?
12/17/2012 11:20 AM
I don't know about distance,but accuracy it does improve.
The same reason why a tennis ball hit with extreme top spin(Like Nadal) seems never to float and go out of the court.
The same thing for a bullet which comes out spinning out of the barrell .
All these are for accuracy.
http://en.wikipedia.org/wiki/Gyroscope
If you don't know where you are going,you are bound to get there
Register to Reply 9 comments
bett4haze (1); bloopertrooper (1); BruceFlorida (1); IdeaSmith (1); kanney (2); lyn (2); srini (1)
