Previous in Forum: Electronic Adjustable Releases   Next in Forum: Please reply fast , its an emergency.
9 comments
Why Silver Color in Power Transmission ?
12/14/2012 1:31 PM
Hi
Why all power transmission equipments like transformer, instrumental transformers, power components inside HVDC station and insulators are painted in silver color?
Good Answers: 114
Re: Why silver color in power transmission ?
12/14/2012 1:34 PM
They are galvanized to avoid the need for painting. Nobody wants to shut down a transmission or distribution substation in order to prep and paint it.
12/14/2012 2:12 PM
Insulators?
12/14/2012 3:13 PM
it makes the red stuff stand out more
Good Answers: 444
12/14/2012 3:36 PM
Although you didn't tell us, I'm going to guess that you are in an area where it's hot and the sun shines a lot. If so then the aluminized coating is there to reflect the sunlight and keep the equipment cooler than if it were painted in a dull dark color.
Re: Why Silver Color in Power Transmission ?
12/14/2012 11:49 PM
Silver color is nothing but galvanizing coating to withstand harsh outdoor environmental conditions for a longer period. However, as far as my observation goes it is generally the steel structures like poles etc., that are galvanized. Transformer and other equipment are properly painted in the assembly lines keeping in mind the challenges of outdoor installations.
B +ve
12/15/2012 9:22 AM
They would look silly painted PINK!
Iran - Member - New Member
12/15/2012 10:26 AM
One of the usual non corrosive and plenty metals in these equipments is GALVANIZED METAL which has a silvered color.
we all switch to perfection
12/15/2012 12:04 PM
Thanks everyone... What I can conclude from this thread is Most of the electrical equipments made out of galvanished metal. So, they are in silver color. Also, it helps to reflect solar irradiation. So, they are not painting in silver color
12/17/2012 5:21 PM
The "silver color" is most likely galvanized paint (or galvanized metal). This is to (1) prevent corrosion in outdoor environment, and (2) provide a remarkable contrast to smoke and fire when they do fail and catch on fire.
Register to Reply 9 comments
AHMAD REZA CHANGIZ (1); Anonymous Poster (1); capri (1); Fredski (1); James Stewart (1); lyn (1); mansoor_vm (1); passingtongreen (1); RAMConsult (1)
