the voulme of the condensor coil tube is 890cm3 the nitogen pressure inside the tube is 7 psi.can u pl guide what is the mass of nitrogen inside the tube..whcih help us to know the consumption of nitrogen ...
830cm3 is the volume of the pipe and of the nitrogen therein. However, I expect a higher pressurized (higher packed/denser) N2 to weigh more than lower pressurized contained in the same volume pipe. Also the temperture, which the original post doesn't specify, is a factor.
0.391m3 of N2 weighs 0.454 Kg at 70°F and 1 atm. source
I suggest keeping the temperature and pressure constant, perharps based on operating conditions, then do the calculation.
Technology solves problems we didn't know existed, or didn't realise that they needed to be solved. Tinkering is therefore never pointless.
