Previous in Forum: Automated Fire Fighting System   Next in Forum: Digtal Positoning of Saw Head
12 comments
Dsp Project
12/19/2012 9:13 AM
i need help!
in want a discrete-time signal processing project , a simple one like using FIR or FFT, with the matlab code.
User-tagged by 1 user
This discussion was "closed" on 12/19/2012 3:37 PM. No new comments are allowed.
Message from admins:
This thread has been closed for future comments.
Re: dsp project
12/19/2012 9:20 AM
  1. I have doubts.
    Below are two of the many sites that suggest projects for lost souls.
    Real-Time Digital Signal Processing Design Projects in an ...
  2. Digital Signal Processing Mini-Project
Re: Dsp Project
12/19/2012 9:47 AM
So what you really want is something "ready to turn in", to your professor; matlab code and all?
Re: Dsp Project
12/19/2012 11:18 AM
yeah if possible!
Re: Dsp Project
12/19/2012 11:36 AM
If you're not willing to work then you won't work. I hope you find a completed project on the web, that your professor catches you for plagiarism and you get ejected from school.
Re: Dsp Project
12/19/2012 11:41 AM
thats because i have so many exams in one week so i couldnt work on the project.. and ur so rude!
Re: Dsp Project
12/19/2012 11:49 AM
Good time management is one of the most valuable tools an adult learns in life. Party Hearty.
Re: Dsp Project
12/19/2012 12:01 PM
You are not only rude, but you're lazy too.
Do your own homework.
Re: Dsp Project
12/19/2012 1:53 PM
Then technically we would get your grade for doing your work for you because if we give you something and then you pass it off as your own work that's called plagiarism.
The last student that tried to plagiarise my work was kicked out of my class and the University.
Also please read the CR4 forum rules, because other than being a question of ethics this is not a homework cheat site.
Re: Dsp Project
12/19/2012 9:47 AM
Great I'm glad to hear that you want to learn how to apply discrete time signal processing. The Z transform is one of the most useful transforms in engineering, IMHO. Technically you will be able to produce a DFT or DFFT (if your sample set is a power of 2) instead of a FFT but most people make this nomenclature error.
What you must ask yourself though is what do you want this project to do. Discrete time signal processing is a tool to be applied to a task.
Re: Dsp Project
12/19/2012 11:36 AM
yes i would like to use the z-transform .. any idea of a simple project with easy procedure , i dont want something deep. i dont have to do it on a kit , just using matlab if possible.
Good Answers: 145
Re: Dsp Project
12/19/2012 10:01 AM
Might I suggest changing "simple" to "interesting". If it is interesting then it will be easy to keep working on it and when you are done you probably will have learned a lot more.
You may also wish to review proper operation of the shift key. People with engineering and technical jobs tend not to communicate via texting. Many engineers won't even read a texting question.
Re: Dsp Project
12/19/2012 3:36 PM
Hello,
This thread is going to be closed per CR4's rules of posting
Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider the following and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other academic assignments is to help you learn - by practice, repetition, and self-discovery.
http://cr4.globalspec.com/faq
“Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.” Albert Einstein
Register to Reply 12 comments
BruceFlorida (1); Chelsey H (1); engh (3); jack of all trades (1); Kilowatt0 (1); lyn (2); redfred (3)
