Previous in Forum: Hoisting Mechanism in Brake Load Concept   Next in Forum: DC Welding
International Standard for Metric Thread Length
12/21/2012 7:08 AM
Is there any international standard available which defines metric thread length ?
Following are the internal threading details for which it is required.
  1. Thread specs : M3 X 0.5 6H, M4 X 0.7 6H
  2. Material Grade: SS316
Regards,
Santoshh,Nasik, India.
Re: International standard for Metric thread length.
12/21/2012 7:14 AM
12/21/2012 7:26 AM
It is thread depth towards periphery of thread.
Actually there is a thumb rule (not written anywhere) said that L/D ratio for internal thread formation should not exceed 2.5mm. According to this, for M3 X 0.5 internal thread it comes around 7.5 mm thread length. Is this assumption is available in any international standard.
12/21/2012 7:42 AM
I beleive the standard is ISO 68-1
12/21/2012 7:50 AM
Some facilities insist on "between three and six turns sticking out beyond the nut".
Good Answers: 34
12/21/2012 8:03 AM
If you have the time & patience, do some research. The links below may help you.
Re: International Standard for Metric Thread Length
12/21/2012 8:19 AM
Thread length should be long enough to assure three full threads of engagement in the mating fastener.
12/23/2012 12:57 AM
Not sure if exist one,but I remember a test done to reveal stress in threaded area
-it took 6 threads to contain normal stress distribution 1Sgma deviation (for coarse
threads)
Register to Reply 7 comments
Jacob Klepatch (1); Joshi (1); JPool (2); lyn (1); PWSlack (1); santoshh (1)
