Previous in Forum: Newbie Wants Some Help   Next in Forum: Normally How Long Could a Jack Support with Oil Inside?
14 comments
About the Cement Paste
12/21/2012 12:05 PM
what are the most important uses of the cement paste ??and what are the problems that we face when using it ?? like cracking .... or any thing else ...
Re: hayyy .. about the cement paste
12/21/2012 12:23 PM
What is cement paste?
12/21/2012 12:34 PM
hayy .. the cement powder + Water + sand
12/21/2012 12:49 PM
search for "properties of cement".
Re: Hayyy...About the Cement Paste
12/21/2012 1:26 PM
CR4 ADMIN: Deleted Post
Politics/Religion: This post was deleted because it was overly religious or political. While each user is entitled to his or her own opinion on these topics, CR4 is not the place for discussion about them. Please review Section 14 of the CR4 Site FAQ and the CR4 Rules of Conduct.
12/21/2012 2:19 PM
Last I checked, Cement + Water + Aggregate (sand or gravel or both) = CONCRETE! Most important uses, hmmm, roads, buildings, bridges, etc, etc......Problems, doesn't last forever, salt attacks it, freeze / thaw cycles play hell with it, get it too wet while pouring, it comes apart, cracks.
Safety - Hazmat - New Member Engineering Fields - Mining Engineering - New Member Engineering Fields - Construction Engineering - New Member Hobbies - Hunting - New Member
Good Answers: 12
12/22/2012 12:48 AM
If your talking like a grout there are many applications. Like pool lining, erosion control, fill under pipes etc. Its a low strength product and can't be used for heavy loads. Pavement, load bearing pads etc. Cracking can be an issue if mixture is wrong, dried to quickly, used in the wrong application, etc.
John J Baker
12/22/2012 5:57 AM
If you google sovereign chemicals , a UK company , you will find info on adding SBR to mortar , screeds , render etc . SBR is widely available from various manufacturers . It is a very superior form of PVA . I used to do tanking ( waterproofing of below ground level walls etc ) and I can vouch for its effectiveness in preventing cracking , adhesion to poor surfaces , workability , strength , waterproofing qualities etc . Main thing is , when you make your mix , allow loads of time in the mixer , and DO NOT make mix too wet . It will seem to become wetter as it mixes , without the need for much water , if you give it time . Best thing is , get someone experienced to show you a couple of times .
Good Answers: 12
12/22/2012 6:46 AM
Not familiar with the acronyms SBR or PVA, but it sounds like a oil we spray on concrete below ground to help it become water resistant.
John J Baker
Re: About the Cement Paste
12/22/2012 12:07 PM
It's called concrete. Get a handyman book to learn how to use it.
12/23/2012 7:07 AM
Give the bloke a chance . Cement , sand and water is not concrete . It might be mortar , screed , render or grout , but not concrete , which needs additional , larger aggregate . Just because he doesn't know the correct terms for the stuff don't mean you can take the p... out of him .
PVA is polyvinylacetate , I think . SBR is styrene-butadeine rubber . The latter is the stuff to prevent cracking etc.
Good Answers: 12
12/23/2012 8:52 AM
GA Thanks for the info on the acronyms been out of the concrete making business for a while.
John J Baker
12/24/2012 2:00 PM
Polyvinyl alcoxy, or acetate, is water soluble and is commonly found in wood glues.
It might act as a binder or adhesion promoter.
SBR is a common O-ring material. Not sure why it would be added to either cement or concrete.
12/26/2012 4:33 AM
dear member
We are using cement paste for following use in my knowledge.
1-Applying to surfaces before plastering
2-Pure cement paste without sand for water proofing and niru coat or final coat in water tanks.
3-to fixed glazed tiles in bath rooms and toilets.
4-Immediate repair of concrete.
5-Applying to joints before new concrete pouring is began.
6-floor tile fixing.
7-Cement or IPS flooring.
list is endless anybody can add some more use.
pravin dhameliya B.E.civil 1994 pass out.
12/26/2012 12:00 PM
Definitely , for most of those uses , SBR additive will help enormously . Mix 50:50 with water , then add cement till its like yoghurt ( creamy yoghurt ) . We usually brush it on with a stiffish brush . It does go off fast , especially in hot weather, so better making a little bit at a time till you get used to it . Then , do the next step of whatever you're doing while it is still tacky . If it goes dry before you get the next step done , you have to put some fresh on .
What additives have you been putting in up till now ?
Register to Reply 14 comments
Ali Mahmood (1); bakerjohn (3); demir (1); JPool (1); lyn (3); pravindhameliya (1); StandardsGuy (1); tomstephens (3)
