Previous in Forum: Thickness Tolerance in Plate   Next in Forum: Why Minimum Cooling Flow to LP Steam Turbine?
Shaft Coupling Material Selection
12/26/2012 6:05 AM
I need to specify material of composition of coupling hub of a pin-bush type shaft coupling fitted to a 200 BHP engine @ 300 rpm, for which OEM data is not available. It OD is 24 inches and shaft bore size is 5 inches.
What may be a suitable material for machining a new hub? Will ASTM A48 CLASS 30 grey cast iron suffice?
Pathfinder Tags: shaft coupling material
Good Answers: 34
Re: Shaft coupling material selection
12/26/2012 7:10 AM
You may find a suitable coupling off-the shelf. You may peruse the links below.
suitable pin-bush type shaft coupling 24" dia for 5" dia shaft
