Previous in Forum: Please Give Suggestion   Next in Forum: Reading Blood Pressure
16 comments
Hell Force Biosafety Cabinet Problem
12/27/2012 5:06 PM
Good Day and Merry Christmas to all!
Sir I have a question regarding with the hell force biosafety cabinet problem.I check the unit and tested but when I inserted to the main source, the fuse of the AVR suddenly blown.And when I check also the fuse of the smps of the hell force biosafety cabinet also blown.
Can you help me what are the possible cause and how to troubleshoot this?I scheduled to troubleshoot the unit this day and this is my first encounter of this unit.
Thanks in advance bro...
Re: Hell Force Biosafety Cabinet Problem
12/27/2012 6:11 PM
Thanks my friend...
12/27/2012 7:34 PM
Heal hath no furry like an AP scorned .
12/27/2012 8:08 PM
If the truth hurts, maybe it should.
12/27/2012 8:17 PM
Quite agree.
12/27/2012 8:21 PM
Here's to your good health.
12/27/2012 8:28 PM
Thanks - and to your's.
If I don't get another chance to say it before the time - have a great New Year celebration (assuming you celebrate!), and a great 2013.
12/28/2012 9:28 AM
If this one turns out like the previous 64 I've seen, I'll just sleep through it and let the kids bang pans, if they can stay up.
Cheers.
Wishing you and yours a healthy and prosperous new year.
12/27/2012 9:40 PM
What is the nameplate voltage of the cabinet? What voltage is being supplied?
12/28/2012 7:57 AM
Somebody will need to explain to AP where the nameplate is located and how to check supply voltage.
12/29/2012 3:16 AM
Thanks for your support bro.Actually the operating voltage is 220 vac.But I solve now the problem.the blower of the unit got a low resistance.
I'm back now in my home in Davao City.Happy New Years to all you my friend.Godbless
Good Answers: 34
Re: Hell Force Bio safety Cabinet Problem
12/27/2012 10:53 PM
I am in agreement with post #8. The operating Voltage for the equipment is not correctly configured.
Re: BIOSAFETY CABINET EXACT BLOWER RESISTANCE
01/17/2013 9:18 PM
SIR I HAve a question again.I need to sure how much the resistance of a Biosafety cabinet blower with 230 volts ac.
I need to check why the fuse of this Biosafety cabinet blown again.Because I suspect the failure in blower part.
I need your help sir...
01/17/2013 9:41 PM
I doubt that anyone here will know the blower resistance, unless they just so happen to have the same unit. Once again, what are the nameplate data on this cabinet? Id the motor 1-phase or 3-phase? Does it have any capacitor? What is the fuse rating?
Is anything blocking the fan from turning?
01/17/2013 10:22 PM
Thats my problem sir, actually the supplier of this BSC don't give me a service manual.All i did is to perform resistance check of the line wire of the blower through the main board of the BSC.The blower have a 230 vac but i dont know if it is 1 phase or 2 phase.But only I know the function of this blower is for Inflow and downflow air velocity of the BSC.
The trouble or problem is when you plug-in into wall outlet the 2 fuse of the BSC suddenly blown.
01/17/2013 10:27 PM
Maybe a loose wire in the unit is touching electrical earth/ground. You should get somebody to check everything with an ohmmeter at least, and maybe even a megohmmeter.
01/17/2013 11:08 PM
OK BUT I TESTED THE GROUNDING OF THE UNIT.BUT NO INDICATION OF SHORTED LINES.
Ok I will try to test again the grounding.Thanks sir
Reply to Forum Thread 16 comments
Anonymous Poster (5); JohnDG (3); Joshi (1); lyn (4); Tornado (3)
