Previous in Forum: Why Autotransformers Always Starts at Zero Position ?   Next in Forum: Cold Saw in Tube Sector
15 comments
India - Member - New Member
Neutral Earthing of 2 LV Diesel Generator Sets Operating in Parallel
01/03/2013 2:00 AM
What should be earthing arrangement for Neutral Earthing for 2 LV Diesel Generator sets operating in parallel. In other words, Is Neutral of one or Both generator to be earthed and why?
The DG are identical and rated 1500 KVA, 415 V.
When was last time you did something for first time.
Re: Neutral Earthing of 2 LV Diesel Generator sets operating in parallal
01/03/2013 7:01 AM
Does it not say in Indian Standard 3043? How about British Standard 7671?
01/03/2013 8:39 AM
How about the operator's manual?
01/03/2013 12:22 PM
No information in Owners manual for earthing.
01/03/2013 12:53 PM
So, you stopped looking, until someone solves the riddle for you?
IEEE 446 (Orange) has a section on gens and grounding.
01/03/2013 12:21 PM
A direct answer would have been helped. Any way thanks for your time.
01/05/2013 6:34 PM
Here's one, then. Open IS3043, and read it.
Good Answers: 444
Re: Neutral Earthing of 2 LV Diesel Generator Sets Operating in Parallel
01/03/2013 1:11 PM
Given the limited information that you provided you did receive a direct answer which is "...No we can't do your work for you..." If you are a consultant and want more help click here.
01/03/2013 3:06 PM
Cut off at the knees, and he never even saw it coming.
01/03/2013 3:21 PM
Provided information is sufficient to reply a smilpe question if YOU KNOW ANSWER.
01/03/2013 3:32 PM
Ground them both, with the ground rods spaced at least one wavelength apart.
01/03/2013 3:38 PM
one wavelength ???
01/03/2013 3:49 PM
Wavelength.
01/04/2013 2:19 AM
Good Answers: 444
01/03/2013 6:56 PM
We know the answer, and we know that the answer depends critically upon the data that you still have not supplied. Your "provided information" is necessary, but not sufficient, to correctly supply the answer.
Before you get in a snit about how you are being treated you should Google on "Neutral Earthing of 2 LV Diesel Generator Sets Operating in Parallel" and see that your posting is the first on the page for all the world, and perhaps your employer/client, to see; then read the next few pages for your answer.
01/07/2013 3:43 AM
Hi there
You need to earth both off them....if they are working in parallel and their is a earth fault then the one not earthed are going to pump into the earth fault and will not trip ...
If the earth fault is big it can trip on phase fault but that will take longer and damage the Generator
Register to Reply 15 comments
Anonymous Poster (1); Happy singh (5); lyn (5); PWSlack (2); RAMConsult (2)
