Previous in Forum: Plug Valve   Next in Forum: Weldolet Beyond MSS-SP-97
8 comments
Dismantling of Convection Furnace
01/05/2013 2:07 AM
Dear Seniors,
I got the assignment to prepare a method statement that "Method statement for dismantling of convection furnace on power plant"..Please help me out.
I will appreciate if some one has same method statement or can guide me the major points in that regards urgently.
Thanks all
Re: Dismantling of convection furnace
01/05/2013 3:21 AM
Perhaps you could contact the maker of said furnace, which we do not know, and ask them for some urgent help.
Or, ask for the method statement for the assembly procedure and reverse it.
Without KNOWING SOMETHING ABOUT THE FURNACE, HOW CAN YOU EXPECT ANY HELP?
Good luck in your new endeavors.
01/05/2013 7:24 AM
I'm not a senior just yet or I'd be all over this one. check back in about 20 years
01/05/2013 7:48 AM
With out knowing more about your particular assignment :
Lock out / tag out fuel and electrical.
Disconnect fuel / electrical
Remove all fuel / electrical systems
Remove exhaust ducting
Remove any support structure
Disassemble furnace
Good Answers: 92
01/05/2013 10:38 AM
How about:
Double check insurance policy
Install dynamite
Triple check insurance policy
Light fuse
Run!!
Call scrap guy to come & pick everything up.
01/05/2013 10:41 AM
I was being sarcastic....
01/07/2013 3:28 AM
There's a lot of that going on.
01/05/2013 7:56 AM
Here is a method statement that you can use as an example....
http://www.epd.gov.hk/eia/register/profile/latest/dir090annexa.pdf
Re: Dismantling of Convection Furnace
01/07/2013 3:35 AM
CR4 doesn't offer a fast-food service.
An Engineer must look to the full detail of the work needed at the site and consider all the hazards and the magnitude of the risks involved in the disassembly of this equipment, and write a safe system of work for others to follow that does not impinge upon the operation of the facility. With the best will in the World, the installation cannot be seen from here. Also, the assignment is going to take some time at the facility, for which some work hours will have been allocated, and there is no mention of the fee nor the transport/accomodation provisions for getting there, staying there, and doing the task. Where is it installed, for instance - Nairobi? Fairbanks?
So the best of success with doing it, as it's going to be a useful learning exercise for all involved.
Register to Reply 8 comments
Fredski (1); JNB (1); JPool (2); lyn (1); PWSlack (2); SolarEagle (1)
