Previous in Forum: Federal Pacific Electric Co. Circuit Breakers   Next in Forum: How to Convert 3 Phase 220V to 1 Phase 220V
Single Set of CT to 2 Power Meters? 3 Phase Meter to Measure 2 Phase?
01/06/2013 11:41 PM
Hi all,
Can I connect a single set of CT to 2 power meters?
Also, can i use a 3 phase power meter to measure the output (load) belonging to 2 single phase?
Thanks!!!!
Iran - Member - New Member
Re: Single set of CT to 2 power meters? 3phase meter to measure 2 phase?
01/07/2013 4:32 AM
Dear friend
you can connect a ct in series with two separate power meters (not as protection or control application).If you use a 3 phase meter to measure 2 single phase loads you have to connect them each one to the neutral point for correct measuring.
we all switch to perfection
