Previous in Forum: MCB Rating for 13A Plug Point for Home   Next in Forum: Polar Mohr Eltromat 72 CE Eletrical Schematics
Gas Insulated High Voltage Equipments
01/08/2013 9:37 AM
Daer All,
I am generally working on Low-Voltage systems. But today, I got a project for High voltage systems. I have no idea about:
1) GAS INSULATED DISCONNECTORS,
2) GAS INSULATED CIRCUIT BREAKERS and
3) GAS INSULATED SWITCHGEARS
Could anyone inform me about their technical properties, how do they work and what is the main differences between them? Is this gas generally SF6?
leirucus
leiurucus - electrical electronics engineer
Re: GAS INSULATED HIGH VOLTAGE EQUIPMENTS
01/08/2013 9:40 AM
01/08/2013 10:07 AM
I'd start here: Switchgear - Wikipedia, the free encyclopedia
Then, after I could converse intelligently about the basics, I'd contact potential suppliers and ask them to enlighten you.
Re: Gas Insulated High Voltage Equipments
01/08/2013 12:16 PM
firstly what means by switchgear ?
it is a general word used to discribe circuit breakers disconnectors earth switch current transformer and voltage transformer
gas insulated switchgear (GIS ) means that all this component included and isolated using gas
the gas used is sulpher hexafluride SF6
disconnectors used only to isolate the voltage on circuit breaker for maintanace becouse HV breakers can not rack out or in (not the load )
Circuit breaker connect and disconnect the load becouse it contain achamper to damp the generated arc
sf6 is about 5 times air in ability of isolation so sf6 breaker compact THAN AIR
eng_yasserelgendy@yahoo.com
01/08/2013 12:44 PM
Then for sake of safety, you probably should pass this project on to someone that does know about high voltage systems. Hire someone.
Register to Reply 4 comments
Anonymous Poster (1); gen protection (1); JPool (1); lyn (1)
