Previous in Forum: I Found a Nesting Software   Next in Forum: Induction Heating Machine for PWHT
Electronics Assembly Discussion
01/09/2013 10:16 AM
Alpha is a leader in product solutions and technologies specializing in electronic assembly materials. Alpha produces advanced solder paste, stencils, fluxes and adhesives focused on power electronics, photovoltaic electricity, and Light emitting diodes (LED). Established in 1872, they have grown to be global leader in innovative materials used in the electronic materials industry. With over 160 locations worldwide, Alpha has the largest research and development capability in the entire industry.
Pathfinder Tags: Electronic assembly
Re: Electronics assembly discussion
01/09/2013 10:25 AM
sounds like advertising.
01/09/2013 10:30 AM
Good. But what about environment? Is there any recycle system?
01/09/2013 11:39 AM
With this technique in mind, please read the following list of pointers about electronic assembly. All of these items are important and will help develop good skills in
assembly:
1. Keep the soldering iron tips away from everything except the point to be soldered. The iron is hot and can easily damage parts, cause burns, or even start
a re. Keep the soldering iron in its holder when it is not being held.
2. Make sure that there is a damp sponge available used for cleaning o and tinning
the tip. Soldering is basically a chemical process and even a small amount of
contaminants can prevent a good joint from being made.
3. Always make sure that the tip is tinned when the iron is on. Tinning protects
the tip and improves heat transfer.
To tin the iron, clean the tip and wipe it on a damp sponge and then immediately
melt some fresh solder onto the tip. The tip should be shiny and coated with
solder.
If the iron has been idle for a while, always clean and then re-tin the tip before
continuing.
4. The tips of the irons are nickel-plated, so do not le them or the protective
plating on the tips will be removed.
[URL=HTTP://WWW.EZDIE.COM/EPAD/2013-MERCEDES-BENZ-SL-CLASS-PRICE-REVIEWS/7980/] 2013 MERCEDES BENZ SL-CLASS [/url]
01/09/2013 12:40 PM
Environmentally friendly universal no-clean solder pastes as well as environmental regulation.Alpha stencil and soldering elements are known worldwide for being high quality innovative products for many different applications.
Register to Reply 4 comments
jasmine131092 (1); JPool (1); MariaB (1); ShereeC (1)
