Previous in Forum: Acid Water Filling   Next in Forum: General Lighting with LEDs
Shielded Cable for RTDs for Generator Winding
01/10/2013 8:27 AM
hai all,
I have 3RTD's in the generator winding, each rtd having 3wires to be connected to the relay. can i use 9core cable with single shield or i have to use 3nos. 3core core cables with shield. scheme shows single 9core schielded cable but im doubtful. pls. advice
Re: SCHIELDED CABLE FOR RTD'S FOR GEN. WINDING
01/10/2013 8:50 AM
As an RTD is a low-impedance signal, the 9-core should be fine.
Re: Shielded Cable for RTDs for Generator Winding
01/10/2013 9:31 AM
Agree with PWSlack, especially since the Operator's Manual recommends it.
Good Answers: 244
01/10/2013 5:04 PM
I would suggest you to use shielded triad instrument cable. In this cable, a bundle of three conductors (called triad) are grouped together and shielded. There may be a numbers of such bundles in a cable. You need a cable of at least three numbers of triad.
Here are some links for the triad:
http://www.eandj-intl.com/product_img/Shielded-Triads.pdf
http://www.okonite.com/instrumentation/Instr_Cable_Std.pdf
- MS
01/12/2013 12:05 AM
thanks to all of you..
Anonymous Poster (1); lyn (1); msamad (1); PWSlack (1)
