Previous in Forum: Difference Between Microprocessor & Microcontroller   Next in Forum: Ransomware/Malware
Save Data from PIC Microcontroller to a TXT File
01/14/2013 9:34 AM
Dear all,
I´ve created a code which reads temperature values by second and would like to save the values on a txt file (by RS232) for plotting. We have used CCS program and PIC 16F877A. Could someone help me?
Regards
Eduardo
Good Answers: 145
Re: Save Data from PIC Microcontroller to a TXT File
01/15/2013 7:43 AM
You might have better luck getting help if you provide a few more details. Does your current code work? How is it outputting data now? Did you use a demo board and if so what ports (ethernet, RS-232, etc.) does it have?
I have done some PIC programming but I don't recall CCS programs. What are they?
01/15/2013 8:17 AM
Have you searched for forums that support your chip and software?
01/15/2013 9:05 AM
I am sure you have been using the hayberterminal communication window that comes with all window versions(XP) . from this page you can copy. i am using the PCM CCS .C compiler and still working on the same micro.pic16f877a. and others
01/15/2013 9:07 AM
Right. Thank you very much!!!
01/15/2013 9:32 AM
Hyperterminal!!!
01/16/2013 9:17 AM
thank you very much Germany .
Register to Reply 6 comments
Andy Germany (2); BruceFlorida (1); caeser (2); EJA (1)
