Previous in Forum: How To Calculate The Thickness of Miter Elbow (SS316)   Next in Forum: Waukesha Engine Giving Detonating Sound.
Material As Per ASME Section II Part A And D & Design Code Ad Merkblatter
01/16/2013 4:23 AM
What are the necessary steps required to design equipment as per AD-2000 code and material used as per ASME section II part A & D?
Duel certification is neccesary of materials?
ie SA240TYPE304 material is to be duel certified with 1.4301
Re: Material As Per ASME Section II Part A And D & Design Code Ad Merkblatter
01/22/2013 7:24 AM
For designing the equipment, no need of dual certification. Allowable stresses can be established as per section B for any material. However if you want to certify the vessel with CE marking , you need prepare PMA and take approval of inspection agency
RK
