Previous in Forum: Reynolds Number For One Dimensional Oscillating Flow Through Pipe   Next in Forum: Material As Per ASME Section II Part A And D & Design Code Ad Merkblatter
How To Calculate The Thickness of Miter Elbow (SS316)
01/16/2013 2:58 AM
Hi?
I would like to know the related codes & standards or calculation method to decide the Thickness of Miter Elbow to be fabricated by SS316 inside biological aeration water tank as shown on the figure below.
At first, I've calculated the Thickness of Miter Elbow by using ASME B31.3 Par. 304.1.2 Straight pipe under internal pressure and 304.2.3 miter bend.
However someone challenged that the applied ASME B31.3 is wrong application since the external force created by water flow to the miter elbow will be existed.
I've tried to find the calculation method to consider both the external force and internal pressure in miter elbow. But I've failed to find it.
So I request your help to this matter as follows.
1. How to decide the thickness of miter elbow? [see No.2 in figure above]
2. Please advise whether the stiffener at neck of miter elbow is necessary. And also please inform me the related stiffener sizing method. [see No.3 in figure above]
Thanks
Pathfinder Tags: thickness bubble miter elbow
Re: How to calculate the thickness of Miter Elbow (SS316)
01/16/2013 3:27 AM
Hint: force is rate of change of momentum.
Re: How To Calculate The Thickness of Miter Elbow (SS316)
01/16/2013 10:12 PM
The differential pressure between the inside and the outside of the elbow is quite small. It might even be altogether exempt from calculation.
Good Answers: 38
01/17/2013 11:57 AM
You are not looking in the right section of ASME B31.3....
There is a special calculation for mitered elbows under pressure, however your situation (pump suction) leads me to believe that there is no significant pressure difference inside vs outside of your elbow.
Try this link: www.pipingoffice.com
Register to Reply 3 comments
MJCronin (1); PWSlack (1); Tornado (1)
