Hello Electrical Engineer forums,
I have a hard problem(for me)
so the problem is i have A breadboard,3 leds, 1 7404 IC(NOT GATE OR INVERTER) and a 9 volt battery.
Problem:
I need to connect the 3 input and outputs of the IC, 1 is the input 2 is the ouput and 3 is the input and again 4 is ouput and so on. up to 7.
Now if i hook up all the wires and leds. if i connect the IC to the positive power it will light the middle led. and if connect the IC to the negative power it will light the 1st and the 3rd led. (vice versa)
Please help thanks! :)
