Previous in Forum: Fit for Needle Bearing   Next in Forum: Centrifugal Force Acting on Rigid Body When it is Rotating
Indonesia - Member - About Me
Angular Contact Ball Bearing (SKF)
01/18/2013 10:24 PM
I want to know, why bearing with bore less than 90mm must be installing with no filling slot, and greater than 90mm must be istalling ? and what is the meaning about filling slot refer to ?
Ex,
now, i want to install bearing 3210(SKF), and i found in cataloge product of SKF, that said like my statement above?
Tq
Re: Angular Contact ball bearing ( SKF )
01/18/2013 10:33 PM
Wiki says,
Slot-fill
In a slot-fill radial bearing, also referred to as a full complement design, the inner and outer races are notched on one face so that when the notches are aligned, balls can be slipped in the resulting slot to assemble the bearing. A slot-fill bearing has the advantage that the entire groove is filled with balls, called a full complement, resulting in a higher radial load capacity than a Conrad bearing of the same dimensions and material type. However, a slot-fill bearing cannot carry a significant axial load on the loading slot side. Also, the slots cause a discontinuity in the races that has a small but adverse effect on strength. Note that an angular contact bearing can be disassembled axially and therefore is a full complement design.
01/19/2013 7:25 AM
than U before for your explanation Mr.lyn.
so, i am clearly yet, the means of fill slot only for got suitable load in the application that we using,,,
and i want to know from you,is it good if i used angular contact ball bearing with fill slot in agitator aplication may be??
01/19/2013 11:22 AM
Don't concern yourself with the "fill slot". It has nothing to do with selecting a bearing.
Angular contact bearing may or may not be suitable for your "agitator application". That is impossible to answer without knowing the agitator's design and requirements.
Best solution is to contact SKF's (or another bearing manufacturer's) technical/design support department.
01/19/2013 11:26 AM
Except for this: "a slot-fill bearing cannot carry a significant axial load on the loading slot side".
The balls may be expelled.
Register to Reply 4 comments
dedek (1); lyn (2); pantaz (1)
