Previous in Forum: Help Locating a Socket for a Strange Bolt Head   Next in Forum: Angular Contact Ball Bearing (SKF)
Fit for Needle Bearing
01/18/2013 4:56 AM
Dear sir,
I have a question, we are designing a shaft (25mm dia) which will run with needle bearings of RNA without inner sleeve, needle roller direct contact over shaft, I need to give the Fit size for the needle bearing roller seating area for the shaft, can you please suggest the right fit for the same
Please help me
Pathfinder Tags: fit
Re: Fit for Needle bearing
01/18/2013 5:02 AM
25 mm, plus clearance per the bearing manufacturer's recommendation.
I'd consult Machinery's Handbook.
Good Answers: 183
Re: Fit for Needle Bearing
01/18/2013 9:27 AM
In the catalogues of needle ring suppliers are such values indicated as function of working conditions. Do not forget the surface hardness, the layer thickness and the roughness as well as the cylindricity, all those geometric and quality parameters are important for the application.
01/19/2013 12:39 AM
Normally when manufacturers make needle bearings, there may be a variance between the needle rollers and their contact surfaces....However, the ID and OD will be manufactured within tolerance. If you plan to remove the IR from an existing bearing, you may be looking for problems. Contact your bearing manufacturer and inquire what shaft size they would recommend. They may want to make the shaft for you so it matches the needle ID envelop as a set.
Remember to be nice to your children, they may one day pick your place of retirement....
Register to Reply 3 comments
lyn (1); New-user (1); nick name (1)
