Where would be the best
locations for HVAC heating and cooling water loop pressure
differential sensors? We have seen them installed
near the end of the loops but the control results are not giving us correct
flow volume at all times. Would a supply sensor near the end of the loop
and a return sensor nearer the pump give us a more accurate indication of what
the DP needs be to provide proper control. The TAB contractor has been getting
his flow by overriding the pump to max. speed with out using the DP control to
signal the VFD for the circ. pump?
