I would like to ask your opinion regarding one problem I have in my LV main breaker (M25 N1, STR 38S, 2500 A), the indication is earthfault; earthfault setting is 500 A. it randomly trips during start of its pumps (2-7.5hp and 1-60 Hp). At other times pumps run without tripping whereas at times it trips usually during start. I conducted insulation tests on the 3 pumps it is supplying as well as the cables from the LV main breaker up to these pumps and all are satisfactory at Giga ohms. During one running of pump I measured the neutral current to see if there is an abnormal spike (it should exceed 500 A to trip the breaker) but only 4 Amps and have not gone up during starting of pump. I am suspecting the breaker as the problem and might be giving nuisance tripping. I am happy of your opinion.
Daniel
