Previous in Forum: PWHT for API 650 Nozzles?   Next in Forum: Tightening a Clamp Using Bolt Tensioner
16 comments
Gear Ratio (Understanding)
01/20/2013 12:11 PM
Hi Ladies and Gentleman,
I always find my self reading through these forums on my spare time and for the past years I must say I have learned a lot, but I do have a question hoping someone can clarify for me. Concerning gear ratios I sometimes run into problems even though is seems pretty simple, hoping someone can clarify.
If a gear ratio is .39:1 with an input of 500 rpm, is the output 1282 rpm? "Increases"
If a gear ratio is 4:1 with an input 2500 rpm, is the output 625 rpm? "Decreased" - Which means when the drive rotates 4 times the driven rotates 1 time?
Samantha
Re: Gear Ratio (understanding)
01/20/2013 12:22 PM
01/20/2013 12:56 PM
GA again, Lyn, great worksheet. @ Samantha, yes, you are correct.
01/20/2013 1:13 PM
Thanks. It beats trying to put it into words.
OP, get your hands on a copy of Machinery's Handbook, any edition.
01/20/2013 5:17 PM
Thank you Lyn for that sheet, here are my results are they correct?
1a: ---> 0.5:1 - RPM will increase
2a: ---> 3:1 - RPM will decrease
3a: ---> 4:1 - RPM will decrease
That is how I would of write the gear ratios but according to the sheet, the ratios would have be written as 2:1; 1:3; 1:4; Is this correct???
01/20/2013 5:43 PM
correct.
01/20/2013 6:21 PM
Thanks jpool, but just wanted to clarify your response, am I correct with 0.5:1 and the sheet 2:1 is incorrect? Referring to the first question on the sheet?
01/20/2013 6:46 PM
You're correct with the first part, but back-to-front with the second. The worksheet explains that the ratio is Driver:Driven, (distance moved by driver:distance moved by driven). So in 1), distance moved by driver = 1 turn, distance moved by driven = 2 turns; ratio is 1:2.
Re: Gear Ratio (Understanding)
01/20/2013 12:58 PM
it depends upon which one is the driver .
for your example if the small gear is the driver one then RPM will decrease by the same ratio ie 5oo*.39/1 = 159 rpm
if the big gear is the driver one then output speed for the small gear will be
500*1/.39 = 1282 rpm and So on.
I hope it's clear
01/20/2013 1:40 PM
The generally-accepted convention is that the first number is the input. 1:4 would produce an increase in speed and 4:1 a decrease.
A motor fitted with a 20:1 gearbox would give 1 turn of the output shaft for 20 turns of the motor.
01/20/2013 5:19 PM
Thank you JohnDG,
so can I say 1:4 is the same as 0.25:1? That should be the same correct?
01/20/2013 5:52 PM
Same ratio, yes. In gearbox datasheets it's usually converted to whole numbers either side of the colon. The ratio is just the number of turns of the input shaft:number of turns of the output shaft.
Sometimes the numbers get silly, like 7:43 - this would be 1:6.1428571428571428571428571428571 or 0.16279069767441860465116279069767:1, so it makes sense to stick with whole numbers.
01/20/2013 7:13 PM
Thank you JohnDG for that explanation. I understand now and it does make sense to stick with whole numbers
01/20/2013 2:27 PM
Your understanding is correct. However, I'm not sure that everyone knows of or follows this convention, so it might be good to spell out both input and output rpm. (Or at least say speed increaser/reducer rather than just x:1 gearbox.)
01/20/2013 2:36 PM
The purpose of gears and transmissions is almost always to increase torque and/or to adjust torque to load thereby increasing efficiency....The first number being the drive and the second the load....In a typical automobile transmission you may start out at 3 to 1 ratio in first, and end at .5 to 1 in high gear....
Wiki has great info...
http://en.wikipedia.org/wiki/Gear_ratio
01/20/2013 5:30 PM
Thank you Lyn for that sheet, here are my results hopefully they correct because that is how I would of write the gear ratios.
Now according to the sheet, the ratios would have be written as 2:1; 1:3; 1:4; Is this correct or am I missing something???
01/20/2013 7:14 PM
Great explanation guys and thanks for the help in understanding gear ratios
Register to Reply 16 comments
JohnDG (3); JPool (2); lyn (2); Samantha77 (6); SolarEagle (1); sphinx49 (1); Tornado (1)
