Previous in Forum: How Long Will the Lights Be On?   Next in Forum: 7SR242 Siemens Relay Knee Point Voltage Cal
Question for Impact of Oil Mist Dispersion at Motor Winding & Terminal Box
01/22/2013 8:58 PM
During the operation (start-up) of the system, we found some bizarre phenomenon from the motors which lubricated with oil mist system for pumps.
- The mist is flowing out from the RTD T/B cable holes during oil mist lube system operation. This is also happened at main terminal box also. There's leakage of oil mist from un-properly sealed gap between motor terminal box and main body.
In this case we concern;
1) The mist would be accumulated inside of T/B if we block the holes. Normally these spare hubs to be plugged tightly. Does the oil mist make any electrical problem (eg. spark etc.) ?
2) What can be occurred at motor winding caused by the dispersed oil mist?
Thanks
Re: Question for Impact of Oil Mist Dispersion at Motor Winding & Terminal Box
01/22/2013 9:48 PM
Nice you have identified the problem prior to failure of winding insulation . Now find the source of oil leakages and then plugged the source first and then dry the motor winding with CRC ( Carbon tetra cloride ) or Petrol to oil mist.
01/23/2013 11:44 PM
Carbon tetrachloride is a toxic material and poses threat to human health. It also emits ozone depleting and green house gas.Hence this material should not be used during maintenance of electrical equipment.
01/23/2013 7:33 AM
Well, it sounds as though this is an explosion that hasn't quite happened yet.
  • Presumably the equipment is shut down until the problem is solved?
  • Presumably the motor manufacturer has been contacted for advice?
  • Presumably the fire protection insurance policy on the facility covers risks of this sort including loss of production turnover?
  • Presumably all CR4 readers are standing well back when the equipment is running?
  • Presumably the Engineer in charge of activities there has Professional Indemnity Insurance cover?
Sheesh.
01/23/2013 11:42 PM
Other perspective:
Check your lubrimist pressures, may be too much, There should not be lot of fumes coming out of your pump bearing housings, probably the laby or the inpro seals are leaking. if only laby and good try and upgrade to inpro seals or similar good shaft seals. Also check the Mist return headers, may be under positive pressures instead of being negative.
01/24/2013 10:45 AM
Are these the motor winding RTD's?
Or are they bearing RTD's?
If they are bearing RTD's there is oil present at all times and it becomes pressurized when the motor runs.
If the RTD's are direct-contact without a protective housing/well, you need to tighten the "O" ring seal adjustment nut and/or replace the "O" ring.
If they are not direct-contact and are installed in a housing/well; you need to remove the housing/well and seal the motor housing/well penetration hole threads with a quality sealant such as oil resistant RTV and make sure there are not any bad welds or other conditions that allow the oil to enter the well.
01/24/2013 12:12 PM
Hello friend,
1.The oil found inside the motor will not harm motor due to that oil is gear oil. B'coz It's 1 kind of insulation oil. motor will not burn. You have time to find out the root cause. Also, check the oil level in gear box. may be excess to the point of mark.
2. Many case we found due to oil seal got damaged that oil is enter into motor as well as TB. But you need to clean with help of petrol with help of paint brush, clean it properlyt.Then, keep that motor stator under room temp for just 10 to 15 minutes. After apply insulation ( winding insulation ), keep under 100 w bulb for 8 hrs.
So, that your motor insulation lavel will not decrease. Also, try to sort out the quality oil seal from market to fix it....!
All the best.......!
sudhir_g_thombare
Register to Reply 6 comments
Anonymous Poster (1); debata07 (1); gsbasha (1); PWSlack (1); SHOCKISCAN (1); sudhir_g_thombare (1)
