Previous in Forum: Reason of Moisture in Bearing Lubrication Oil   Next in Forum: Bending of a Rectangular Hollow Section
11 comments
Aluminium Extrusion
01/23/2013 3:13 AM
i am not succeess in extrusion of solid round bar of boron/aluminim,
i use regular shape die or conical both die i use for, but the surface finish is not ok it very ruf finish,
tempture and pressure is ok but i request u pls any
one have idea about the die shape so i request to suggest me
-------pankaj
CR4 ADMIN - phone number removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
Pathfinder Tags: aluminium extrusion
Re: Aluminium Extrusion
01/23/2013 9:39 AM
We need a lot more information to help you.
Surface cracking is often due to speed being too high, or temperature too low.
Rod sizes, process involved, lubrication... please tell us more
01/24/2013 12:55 AM
Thankyou very much......
material is AL3B (Aluminium 97% + Boron 2.5 to 3%)
extrusion speed is 5 to 9 mm
temp is 400 to 420 degree celcius
billet size 85mm
road size 45mm
container length 17 Inch
Die which i use is one conical type the other is bearing type 5 & 25 mm
ok thanks again
----- pankaj
01/24/2013 1:31 AM
The process of aluminum die-casting is a proper solution to get complicated heatsinks in shape. Compared to aluminum extrusion, for special shaped heatsinks, aluminum die-casting could save much cost of further machining. Thus, aluminum die-casting is widely applied in notebook chipset cooling and industrial cooling. Normally, the material used for aluminum die-casting is ADC12, whose coefficient of thermal conductivity is 96W/mK and just half of that of aluminum extrusion. Another disadvantage of aluminum die-casting is high tooling cost input.
I am turned into a sort of machine for observing facts and grinding out conclusions——http://industrialmachine1.appspot.com/
01/24/2013 5:14 AM
Yes Thankyou....
01/24/2013 9:24 AM
Here Jesse, I'll credit your comment for you. We generally consider it bad manners to not do so.
I don't believe the casting and extrusion processes can be directly crossed in this circumstance.
01/24/2013 11:55 PM
Hello Doorman,
i have extrusion plant, so i want to do this process in my plant, not casting
u can see more detail i post is it ok ? or tell me if u want to know more,
pls give me some suggestion in extrusion process, die design or any thing
-------- pankaj
01/25/2013 10:36 AM
I would first ask about your material selection:
I believe your Al3B is giving you the trouble, the alloy better suited to casting. Was this selected by a material engineer?
01/26/2013 6:12 AM
material is ok, that is given by my clint, pls give me advice about die design or somthing more
01/28/2013 10:45 PM
01/29/2013 8:41 AM
The material is inappropriate for extrusion process.
If he gave you a bundle of pig ears, could you make them into silk purses?
01/31/2013 12:07 AM
ok Doorman... Thankyou.... now i understand
Register to Reply 11 comments
Doorman (4); JesseConant (1); pankajp (6)
