Previous in Forum: Design of Idler in Conveyor System   Next in Forum: Aluminium Extrusion
16 comments
Reason of Moisture in Bearing Lubrication Oil
01/22/2013 7:19 AM
Can anyone tell me what are the major reasons of moisture in lube oil?
Re: Reason of moisture in bearing lubrication oil
01/22/2013 7:21 AM
Please describe the installation in which moisture-bearing lube oil has been discovered.
01/24/2013 12:14 AM
Dear PWSlack, Moisture is found in Splash lubricated system for bearings.
01/24/2013 12:17 AM
Maybe the bearing went swimming or something.
01/24/2013 9:25 AM
Slash lubrication implies a free space volume along with aggressive agitation of the gas in this space into your lubricant. This begs the question, what has been done to prevent water vapor from existing in this space? This does not preclude active or accidental tampering of the oil prior to use.
Good Answers: 266
01/22/2013 7:29 AM
Condensation or seal failure from coolant system.
Re: Reason of Moisture in Bearing Lubrication Oil
01/22/2013 7:52 AM
Is the lube oil in storage? Or is it in an installation?
More input needed!
01/31/2013 11:05 PM
Dear IdeaSmith, Moisture has been found in Splash lubricated system for bearings. Can you suggest what could be possible reasons of that?
01/22/2013 9:32 AM
Dear Mr. naumanmalik825,
Breather might have failed.
Pl. Describe your installation.hanks,
DHAYANANDHAN.S
01/31/2013 11:08 PM
Dear dhayanandhan, Moisture has been found in Splash lubricated system for bearings. Can you suggest the main reasons of moisture in Splash Lubricated system?
01/22/2013 11:20 AM
"Water can originate from a variety of sources. Examples of environmental ingression are rain leakage into external reservoirs, seepage through reservoir covers, access panels, breathers or worn seals, and condensation from air in reservoirs and other system areas. Water can also enter the fluid system from the process side, from leaky heat exchangers or coolers, or direct ingression of process water, such as cooling water, washdown water or steam. Water ingression can be minimized with clever system design and good housekeeping, but it is difficult (and costly) to eliminate all sources of water entirely ."
http://www.machinerylubrication.com/Read/1084/water-contamination-lube
01/22/2013 12:50 PM
Cold machinery or environment.
01/22/2013 1:26 PM
"Cold machinery or environment."
Perhaps the 710 cap is missing, and the fill neck is exposed to the environment.
01/22/2013 2:13 PM
I could also just be Clancy letting his Guinness to run past his kidneys. They warned them not to irritate Clancy.
01/22/2013 2:53 PM
Ah, you may be correct, the 710 filler neck exposed to other sources of moisture.
01/23/2013 3:50 AM
Pl. refer my post No.4, I for got to add - if cooling coil is used, for removal of the Heat from the Oil, or Forced Lubrication System, cooling water is leaking and mixing with the oil - that is one source for water contamination and it will create problem.
You have not mentioned the installation details. Unless you furnish correct installation, duty parameters etc. it is difficult to comment or suggest.
Thanks,
DHAYANANDHAN.S
01/31/2013 11:43 PM
The major reason that water can be found in lube oil is that about 70% of the surface of the Earth is covered in water. Your oil will be perfectly dry if you move to Venus.
Register to Reply 16 comments
dhayanandhan (2); Doorman (2); IdeaSmith (1); naumanmalik825 (3); ozzb (1); PWSlack (1); redfred (3); SolarEagle (1); Tornado (2)
