Previous in Forum: Process Safety   Next in Forum: Current Transformer
Minimum Gap Between Temperature and Pressure Tappings
01/25/2013 12:12 AM
I am having a direct contact type temperature measurement in water pipeline.I have to weld thermowell in the pipe which is also having pressure measurement.in my case temp measurement comes ahead of pressure measurement.I want to know the minimum distance between temp and pr measurement.so tat my pressure measurement won't get affected bcoz of temp measurement.
it s condensate water system with 25 bar pressure and max 150 deg temp.
Re: Minimum gap between temperature and pressure tappings
01/25/2013 3:35 AM
The minimum distance in the pipeline would be where the two tappings are on the same circumference of the pipe, i.e. zero spacing along the length of the pipe. Without knowing some dimensions, this is best addressed at site.
Good Answers: 21
Re: Minimum Gap Between Temperature and Pressure Tappings
01/28/2013 4:05 AM
You state pressure measurement, which implies a simple tapping into the line.
The thermowell may briefly change the flow characteristic in the pipe, depending on the ration between it's length and the pipe diameter, but the pressure will remain constant. Try and mount the thermowell downstream of the pressure tapping if possible.
