Previous in Forum: HV Cables   Next in Forum: Double Pole Circuit Breaker - the Sequel
BELT Sway & Pull Cord Switches
01/28/2013 12:11 PM
What is the control voltage normally used for BELT sway & pull cord switches for belt conveyors? and how is it decided?
Good Answers: 73
Re: BELT sway & pull cord switches
01/28/2013 12:20 PM
Since you would typically be monitoring this with some sort of PLC, you might see this done at line voltage (120 VAC in the US) or more commonly now using dedicated DC devices operating at 24V. With all of the push to redundant safety devices, 24VDC is becoming the most common.
Good Answers: 181
Re: BELT Sway & Pull Cord Switches
01/28/2013 6:24 PM
Whatever voltage you like.
01/28/2013 6:35 PM
I'd use enough, but not too much, for the application at hand.
lyn (1); NotUrOrdinaryJoe (1); TonyS (1)
