Previous in Forum: Back Pressure/ Full Back Blow   Next in Forum: Isogen
Design Of Mandrel Automatic Rotating Mechanism For An Autoclave
01/30/2013 1:52 AM
this is my project and any ideas regarding this please post me as soon as possible or email address removed - cr4 admin
madrel (hollow cylinder) specifications are
3m diameter
12m length
10tones weight
at a speed of 0.1rpm cyclic
auto clave constrants are
200degrees temperature
10bar pressure,.,.,.
Good Answers: 141
Re: design of mandrel automatic rotating mechanism for an autoclave
01/30/2013 2:33 AM
We are no private internet mail CR4.
OK it is your project? How do you heat it up? How do you isolate it? What will be inside? What material is the autoclave made of?
What do you want:
drive mechanism? Heating sytem? Doors? Windows? Robots? Bring it on.
Plenty of room here
01/30/2013 4:38 AM
ya it's my porject....... and my job is design a rotating mechanism only...... auto clave is already designed and its in use now
a composite material (mandrel) which should be supported will be inside.... so we have to support the mandrel and rotate it at 0.1rpm... (180° in 5minutes and it should be counter clockwise also)
we need a idea for supporting the structure and rotating it
01/30/2013 8:33 AM
Do your own homework.
Look at a rotisserie on a Bar-B-Q grill. It's supported at both ends and goes round n round.
01/31/2013 12:23 AM
ya it's a good mechanism even i have tried it..
but i need to rotate 180° clock wise and 180° anti clockwise..... at a rate of 0.1rpm..
i.e it should rotate 36° for every minute
02/05/2013 12:11 AM
any other idea,,.,.,? plz let me know,. right now i'm working on supporting the structure(cylinder) then i have to work on the rotating mechanism,.,., i can reduce the speed by gear box,. but i need some innovative rotating mechanisms,.,.,,.,.,. the rotation is of clockwise and anticlockwise,.,.,
01/30/2013 4:55 AM
Register to Reply 6 comments
Anonymous Poster (1); dvmdsc (1); lyn (1); manojlouis (3)
