Previous in Forum: Steam Turbine (SST-9000)   Next in Forum: Design Of Mandrel Automatic Rotating Mechanism For An Autoclave
Back Pressure/ Full Back Blow
01/30/2013 12:34 AM
Dear All,
Please advise the possible causes of 60 kVA, Himoinsa D/G genset failure:
@ Engine is giving full back blow / back pressure
@ High lube oil consumption
@ Abnormal noise coming from turbo
@ Engine internal temperature is at danger side
Is thsi relates to wear and tear OR breakdown?
Thanks,
Irfan
Re: Back pressure/ full back blow
01/30/2013 1:12 AM
I don,t know about Himoinsa , Is it petrol or diesel engine?
is it new or old engine.
all these troubles not happened suddenly , it mostly start by one or two and if not treated ,it grows up and causing more troubles.
is there any repair works done in the near past.
01/30/2013 4:01 AM
Simple answer? It's f%$£*&%d.
Long answer? It needs either a strip-down, and the tired parts renewed, or wholesale replacement with a new piece of equipment.
Re: Back Pressure/ Full Back Blow
01/30/2013 9:19 AM
Call the service tech and get it fixed. Don't muddle around with it yourself, you'll just make it worse.
Register to Reply 3 comments
lyn (1); PWSlack (1); sphinx49 (1)
