Previous in Forum: Suitable LPG pumps   Next in Forum: Steam for Online/Offline Washing of Gas Turbine
11 comments
Electric Hoists
02/04/2013 2:41 AM
Dear Friends,
In a large water pumping station, we need to replace electric lifting hoists (SWL 3 to 5 t). Several of the existing hoists are chain hoists while some are wire rope type. The lift height is a maximum of 6 m.
Is there a criteria one can use in deciding which type to use i.e chain or wire rope.
Kind regards
Pathfinder Tags: Lifting Hoists
Good Answers: 21
Re: Electric Hoists
02/04/2013 3:11 AM
Largely depends on what your lifting and how fast you need to do this. It also is dependent on ambient temperature etc; But for the most part, it falls to personal preference.
Re: Electric Hoists
02/04/2013 4:05 AM
Dear Mr. fixitorelse,
Kindly inform how the ambient temperature is involved. I am eager to know on this point.
My suggestion, posted will indicate EOT CRANE, to be installed - for which my inferences are to be confirmed, by Mr.Mohammad Akram Khan.
thanks,
DHAYANANDHAN.S
Good Answers: 21
Re: Electric Hoists
02/04/2013 11:04 PM
Hot metal handling you may not want to have a chain, cables are far more forgiving.
Re: Electric Hoists
02/04/2013 3:53 AM
Dear Mr. MohamadAkram Khan,
Some more details are required. What I understand from your post - is
1.That each pump has one hoist, only lifting/lowering - single motion up or down.
2. Do you intend to install EOT Crane, for replacing the existing hoists. If so, what is the Span for travel and traverse.
If my inference is correct, which you have to confirm, pl. specify that (a) Span for Travel, Traverse, and Lift as you mentioned. (b) Pl. Specify the Motor should be Crane Duty Motor. (c) Pl. specify the Pulley/Rope Ratio should NOT be less than 20, so that the life of Rope is not shortened. (d) The deflection should NOT exceed L/900 where L is the Span in the Long Travel. Some Countries adopt L/800 as the Ratio for DEFLECTION. (e) Ask for Wire Rope with HEMP CORE.
Let us see the Views of other CR4 Members
Thanks,
DHAYANANDHAN.S
Re: Electric Hoists
02/04/2013 4:19 AM
Thank you for your response.
Let me please clarify:
1. The gantry granes are existing and we are only replacing the hoists. The existing hoists are chain blocks and these will be replaced by electrically-operated hoists.
2. The longitudinal and transferse travel will remain the same i.e. manually-operated. Only one hoist is to be installed for 3 to 4 pumps.
Kind regards
Re: Electric Hoists
02/04/2013 3:47 PM
I would contact a couple of hoist manufacturers for recommendations.
Some things they might need to know:
Budget?
Any relevant safety code (i.e., OSHA) compliance required? (The manufacturers may have this information, but you should verify it yourself.)
Are the hoists used every day, or only for annual/infrequent maintenance & repair?
Re: Electric Hoists
02/05/2013 9:38 AM
Thanks for your comments.
The hoists are for infrequent miantenance purpose only.
Yes, budget is also an important factor. For a given SWL, which hoist (chain or wire rope) require less capital investment ?
Re: Electric Hoists
02/05/2013 6:42 PM
"Yes, budget is also an important factor. For a given SWL, which hoist (chain or wire rope) require less capital investment ?"
I haven't done any price comparisons. Do some basic research on what products are available and in your price range, then call the manufacturers for recommendations based on your specific requirements.
In my opinion, it's preferable to contact the manufacturers directly, rather than a distributor. The distributors are more likely to recommend products that can make them the most money.
Re: Electric Hoists
02/06/2013 2:22 AM
Thank you for your comment.
I fully agree with you about dealers !
Re: Electric Hoists
02/06/2013 8:36 PM
Also keep in mind the environment. Wire rope tends to corrode from the inside out where moisture becomes trapped. This makes it difficult to detect a cable no longer suitable for service. This is one reason why we don't use wire rope hoists. Chain type is easier to inspect.
Re: Electric Hoists
02/07/2013 1:11 AM
Thanks for your comment. Moisture is no doubt an important factor to be considered
Register to Reply 11 comments
dhayanandhan (2); fixitorelse (2); Mohamed Akram Khan (4); pantaz (2); TerraMan (1)
