Previous in Forum: Nokia E Series Handset   Next in Forum: Refrigerator
Bipolar Transistor
02/04/2013 9:14 PM
Can we say bipolar transistor used for power amplification as a dc to ac converter?why?
Re: Bipolar Transistor
02/05/2013 4:26 AM
Say it, sure, though the question makes no sense.
Good Answers: 116
02/05/2013 6:22 AM
I have used a standard linear 20 watt bipolar transistor sound amplifier at 50 Hz to boost a signal generator (about 50 Hz, 100 mV rms 0.1 milliamp) to 110 VAC, 3 watts, through a power transformer. In that case, it is certainly "power amplification", with "HiFi" accuracy. Inside the amplifier, all is powered from + and - 22 volts direct current - all the AC output power comes from that DC (which could be two batteries) - so it could also be called a "DC to AC converter". But you must take care with the meaning of "power amplification" - an electromagnetic relay with a coil current of 10 mA switching 25 amps at 240 V DC, which then closes the main breaker on a 1000 MW 60 Hz generator, is also "power amplification" - but amplification does not have to have transistors or an AC output.
02/06/2013 4:42 AM
And what will you call a PC then...
It takes DC and does all sorts of things and it uses transistors, even bipolar.
Gajanan Phadte
Register to Reply 3 comments
67model (1); gmphadte (1); PWSlack (1)
