Previous in Forum: Please help me know   Next in Forum: Camcorder as a cam to VoIP
high >< low frequency
05/26/2007 4:33 AM
Dear friends,
What is the difference between high and low frequency transformer?
Pathfinder Tags: transformer
Re: high >< low frequency
05/26/2007 5:23 AM
Core material and physical size.
Switched mode power supplies operate at high frequency so that the transformers (and chokes) can be small ferrite ones rather than big steel ones.
(Del the Cat....not logged in!)
05/26/2007 11:18 AM
so , much higher frequencies ,
(over 150 Khz dont need an metallic core,
Air coils can transforme any needed Kilowatts.
AM- Transitter (Radio) LW about 200Khz MW about 1 Mht SW about 10Mhz FM 100 Mhz
For understand first steps
look (google) TESLA COIL , Tesla transformer . about 100Kz to 500 Khz typical
Pic of an "bigone"
http://pixerve.de/60240/a-fe-pese.html
05/27/2007 3:18 PM
Core material & its thickness. Higher the F thinner the core laminations. Power transformers go upto 1MHz now with Soft-magnetic material. After that no core material is used.
05/27/2007 6:50 PM
It depends on what you call low and high. Low freq. audio and power transformers may be laminated iron core, but a lot of them today use a toroid which is powdered iron or ferrite. Higher freq. audio would use a toroid. For RF applications there are toroids designed for different frequencies. As already mentioned, air core can be used if the freq. is high enough. As the freq. increases, the number of turns drops and the size of the wire and the spacing increases to give the coil a higher Q. Often the coil is wrapped around a hollow ceramic form.
05/29/2007 7:25 AM
there is not strictly distinguishing between them.
what their core material depends on power dissipate.
Anonymous Poster (1); cnpower (1); Haajee (1); Pese (1); StandardsGuy (1)
