Previous in Forum: Engine Oil Goes to Intake Via Oil Air Separator   Next in Forum: Non Self Locking Worm Gear
Pressure Drop in a Pipe Calculation
02/10/2013 6:55 PM
I am calculating various pressure drops in a pipe and am and am having trouble calculating the pressure at a certain point, for a set case. This is the pipe...http://i50.tinypic.com/141mikg.jpg
A and B are vents, through which air passes and travels on up the pipe, where is it discharged to atmosphere. I am working out the pressure at points a and b for three cases.
1) both vents open and pumping air
2) vent A open, vent B closed
3) vent A closed, vent B open
I have worked everything out no bother for cases 1 and 2 but 3 is stumping me. My engineering brain knows that there should be a vacuum effect at a, because of the flow through b onwards, but I can't work out how to do the calculation. So far, setting the flow rate at a to zero just makes the frictional losses zero at this point, and leaving it at the same pressure as at b ... which isn't right!
I have accounted for losses due to the fittings (inlets) in my calculation.I would like to know a method to calculate pressure at a when vent A is closed.
Thanks in advance.
Good Answers: 32
Re: Pressure Drop in a Pipe Calculation
02/10/2013 11:26 PM
Pressure is force per unit area. You also know it by PV = RT.
Good Answers: 183
02/11/2013 8:18 AM
It is not sure that you get a vacuum. According to Bernouli's law in a flow the sum of static and dynamic pressures is constant. In your case due to the resistance of the pipe from B to atmosphere it could happen that static pressure at B is over the atmospheric pressure and thus no vacuum.
In an ejector vacuum occurs after the nozzle where the pressure is the outlet pressure and the fluid has its maximal velocity thus its smallest static pressure.
If you compare with your sketch B is in front of the "nozzle".
Good Answers: 32
02/11/2013 10:11 AM
If you make air flow through B and air flows in same direction then pressure near A will drop down. This technique we use for shucking gases by forcing air and creating low pressure behind due kinetic energy.
If you make air flow through A and it flows in the same direction, then also air from B will be shucked in but not to the level it will do in case before.
Mathematically one need to workout all developed pressure at various points and flow achieved due to pressure drops. If you forcefully stop the flow, then things will be very different and that says about the pressure distribution in the duct.
02/11/2013 1:10 PM
Acording to the sketch, both ends of the large pipe are open. If this is true it changes things. Also some dimensions would be nice.
You'll need to say if this is true and how high the exhaust stack is, if it is closed on the "bottom".
Or is it horizontal, as drawn?
Good Answers: 32
02/11/2013 1:24 PM
In fact both ends of the pipe can be open in free air even then the injected gas through inlet A or B can make flow only towards one side of the pipe and both ends of the pipe will also see pressure difference and flow. Air flow in any pipe will cause air flow in all pipes. This makes pressure changes in all pipes. Any pipes end having closed is as good as not being present in the duct or pipe assembly.
I have used one with similar design having a pipe and only one injector which also drags air from free end along with flow. Such forced flow using injected air can be seen in many applications.
lyn (1); nick name (1); Shyam (3)
