ASME Section IX QW-404.5 (Applicable
only to ferrous metals.)
"(c) For GMAW and EGW-from the chemical analysis of the weld deposit
prepared according to the filler metal specification or the manufacturer's or
supplier's certificate of compliance when the shielding gas used was the same as
that used to weld the procedure qualification test coupon."
"(d) For SAW-from the chemical analysis of the
weld deposit prepared according to the filler metal specification or the
manufacturer's or supplier's certificate of compliance when the flux used was
the same as that used to weld the procedure qualification test coupon. In lieu
of an A-Number designation, the nominal chemical composition of the weld
deposit shall be indicated on the WPS and on the PQR. Designation of nominal
chemical composition may also be by reference to the AWS classification,except for the "G" suffix classification, the manufacturer's trade
designation, or other established procurement documents."
A s per this clauses, Can I accept the result taken from Arcmet-8000 optical emission spectrometer (spark type PMI equipment) as chemical analysis? The result contain all the elements including carbon as per corresponding SFA number in ASME Sec II Part C requirement. Or should I follow other method for Chemical analysis?If,so pls give the details of the test to be conducted.
Thanks,
San
