Previous in Forum: Symbols Library   Next in Forum: Here is Engineering Humor Section
DIY the Tumbling Media
02/17/2013 12:00 AM
can any one guide me to made(DIY) or find cheep tumbling media for aluminium parts.?
Pathfinder Tags: Finish media polish tumbling
Re: DIY the tumbling media
02/17/2013 12:03 AM
Good Answers: 50
Re: DIY the Tumbling Media
02/17/2013 4:26 AM
What is the tumbler? Is this DIY, concrete mixer type?
What type of deburring are you trying to do? Remove casting flash, sharp edge from press brake operation, machining operation. How big are the parts?
Your previous post was on repair of mold for die casting. Hope that worked out well. But more information on the part, and what the tumbling operation is needed for.
ignator -
02/17/2013 11:27 PM
we DIY a Tumbler, hexagonal sides, Aluminum part dia is 160mm wall thickness 3mm, just like a plate, after die casting, we press trim, so there is miner burr at outer dia.
but main problem is while casting a cloud appear on its surface, we know its a cause of mold release spray and recycle old material.
so we like to finish its surface, remove the clouds to get a semi polish finish.
02/24/2013 10:19 PM
2000 grit wet sandpaper might be a better alternative for something that shape.
You don't say what your daily output is.
02/25/2013 12:48 AM
we have production of die casting parts daily 500pcs.
129CBRider (1); ignator (1); lyn (1); saide (2)
