Previous in Forum: Screw Compressor Problems   Next in Forum: Which is the Better Compressor to Buy (10HP, Should Be Able to Produce 30 CFM)
10 comments
Sheet Metal Mounting Ways
02/18/2013 12:53 AM
Hi ,
Can anyone please suggest me any alternative way for sheet metal mounting other than PEM's , rivets & Welding
Re: Sheet metal mounting ways
02/18/2013 1:51 AM
Adhesives.
02/18/2013 1:55 AM
Adhesive
Brazing or soldering (not technically welding)
Tape
Magnets
Suction cups
Clamps
Hire an attendant to manually hold the sheet in place
02/18/2013 8:02 AM
may i know hw section cups work ?
I want mounting to be as strong as welding..whether the above mentiond methods ll be as stong as welding?
02/18/2013 10:15 AM
Short of properly formed interlocking profiles, welding is the appropriate solution for permanent and reliable joining of steel parts.
Is there something to contraindicate welding?
02/18/2013 6:18 PM
the best suction cups will not come near the strength of a decent weld.
Most of those were suggested in jest.
Brazing or Soldering, and Adhesive are methods for attaching sheet metal that can be a high strength alternative to welding in some cases. An example of this would be titanium sheets with are joined by vacuum brazing with aluminum.
02/18/2013 7:43 AM
Press fitting.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Re: Sheet Metal Mounting Ways
02/18/2013 1:17 PM
Stacking.
(all the common ways have already been mentioned).
What is the application exactly?
02/19/2013 12:52 AM
We have sheets metal parts which are used in gaming machines..we need to fix them on those machines so are looking for an alternative way other den whic i metioned above
02/19/2013 9:56 AM
You have still not told us if these assemblies are intended to be permanent.
In general, the panels should probably be removable. How about interlocking tabs and slots, with a few screws to ensure the parts don't unintentionally slide apart.
02/19/2013 1:54 PM
We are discovering other methods then screws pems and all i guess adhesive ll be the best choice to look into
Register to Reply 10 comments
Doorman (2); jack of all trades (1); pantaz (1); ronclarke (1); sanji (3); truth is not a compromise (2)
