Previous in Forum: Water Vapor Effect On Climate Change   Next in Forum: Network Conduit Secured with Wire Ties
Gi Strip
02/19/2013 8:34 AM
Pl. explain how to joint the gi strips . Normal lenght will come from 5-7 mtrs each. We require 100 mtrs running lenght
Re: gi strip
02/19/2013 8:48 AM
You should contact other manufacturers if yours is only offering it in 5-7 meter lengths. I'll get you started, here's a list from GlobalSpec and here's a list from some other site.
The first law of thermodynamics is you do NOT talk about thermodynamics.
Re: GI Strip
02/19/2013 10:24 AM
Although the manufacturer will give you the best method,
Bu i think you can bolt the joints, if the GI strip is thick enough > 3mm , you can weld it with a 309L welding.
regards
Sanjay
Re: Gi Strip
02/19/2013 1:33 PM
Please explain what a Gi strip is?
Re: Gi Strip
02/19/2013 1:39 PM
I think it's Galvanized Iron in this case?
Re: Gi Strip
02/19/2013 1:44 PM
Oh, then.....
What is the thickness of the Gi strip (1mm, 1 foot, etc)?
What is it being used for (is it structural, etc)?
Why has your handle got the word 'electrical' in it, is this Gi strip for earthing or carrying current or something, as this effects the joining method?
Please provide more information.
jack of all trades (2); Mizuti (2); sanjayb (1)
