Previous in Forum: Golf Cart Battery Problem   Next in Forum: Power Hardware in the Loop
DC Motor Bi-directional Speed Control
02/20/2013 1:29 AM
Bidirectional speed control for DC motor.
Rated voltage: 300V
Rated current: 1.4A
Rated speed: 750 rpm
Rated torque: 2.8 NM
Armature resistance: 6.6 ohms
Field system: Permanent magnet
Maximum limit for
instantaneous current: 4A
Armature inductance: 20 m.H
Backemf constant: 240V/ k.RPM
Inertia: 0.0205 Kg. M2
how can i select switch for this data guys
padupoi
Re: DC Motor Bi-directional Speed Control
02/20/2013 1:51 PM
Why not just get a DC motor controller rather than playing around with switches and simple control elements that limit your ability to control and protect the motor and whatever it is connected to (and are unsafe at this voltage level).
For example Dart Controls . They aren't expensive and this is the most common method of motor control unless you want really simple on/off/reverse control, in which case you use a changeover switch with a centre off position and wait for the motor to stop before reversing direction (although I would NOT recommend this method for a 300V DC motor).
Jack - Used to sell and service Dart controllers.
Good Answers: 42
02/20/2013 11:56 PM
Using switches for starting across the line will cause in rush of about 50 amps - 10 x the max allowed.
Register to Reply 2 comments
