Does having 480VAC run through a panel increase its NFPA70e rating?
I am working with a vendor that wants to run a high voltage wire (480VAC) through a 24VDC panel to reach another 480 panel. The wire will not terminate in the panel, but will run through the tray in the low voltage panel. Will having that wire in the panel increase the energy level and by that increase the category of the panel?
Thank You,
