Previous in Forum: Measurement of Earth Resistance Value   Next in Forum: Does Having 480VAC Run Through a Panel Increase its NFPA70e Rating?
10 comments
Induction Motor Starting Current on "NO-Load" and "ON-Load"?
02/21/2013 6:45 AM
Dear All,
(1) I want to know, whether there is any difference between starting current of induction motor on NO-Load" and "ON-Load"??
(2) How to calulate Motor starting current and No-Load Current?
(3) Is there any limit or IS for acceptable value of Motor starting & No-load current with respect to % of FLC or something.
Regards,
T.D.
Re: Ind. Motor Starting Current on NO-Load" and "ON-Load"??
02/21/2013 8:19 AM
(1) Yes, the starting current can be significantly larger than the unloaded current. Why do you think many induction motors have a centrifugal switch connected to starter windings?
(2) I have not bothered to calculate any motor current conditions since I took a motor fundamentals class. There are many additional parameters (core losses, windage, bearing drag, squirrel cage topology and materials, poles, gaps, etc.) that must be known to calculate the motor operation. I prefer to use the motor manufacturer's specifications.
(3) Yes, there is an upper limit to the current that can be driven into any power grid driven device. That limit is usually established by the core saturation of an upstream transformer. The only time this needs to be known is in calculating the arc flash condition. (Same class) For safe usage of a motor, just follow the manufacturer's data in selecting proper circuit protection.
Good Answers: 42
Re: Induction Motor Starting Current on "NO-Load" and "ON-Load"?
02/21/2013 9:31 AM
The induction motor start current does not depend upon load, but the starting duration does. For D.O.L. [direct-on-line] start, the current will be the same as locked rotor current[See NEC Table 430.7(B) Locked-Rotor Indicating Code Letters]
Net acceleration torque for any speed S is Tacc=TM-TL [this would be slight variable and we should state it is constant] where:
TM=motor torque TL=load torque
tstart=wk^2*(ωmax -0)/Tacc/308
TMrat = Php 5,252 / ωmax [rated torque-lbs*ft]
Php=Motor rated power [HP]
ωmax= Motor rated speed [rpm]
If it is NO-LOAD motor start TL (approx..)=0 then Tacc=TM then tstart will be very short.
See also:
Re: Induction motor, inrush current vs locked rotor current
Julius
02/22/2013 12:50 AM
If no load current is stamped on the nameplate we need not guess it. Similarly the maximum load(inertia)which a motor can start and the time taken to start should be stamped in the nameplate.
pnaban
Good Answers: 137
02/22/2013 4:31 AM
I've never seen no-load current on a motor nameplate.
It's not as low as you might expect (20-30% FLC springs to mind, but don't quote me) as the power factor is very low in those conditions.
Good Answers: 804
02/21/2013 5:44 PM
Maybe we could help you more if you were to divulge why you are asking these questions.
Good Answers: 42
02/22/2013 2:52 AM
If we should take Steinmetz Equivalent Circuit and we could establish the Xrotor and Rrotor for a slip=1[slip=(rpmsynchron-rpmactual)/rpmsynchron] for rpmactual=0 at start [see for instance: https://www.selinc.com/WorkArea/DownloadAsset.aspx?id=3690] neglecting Xm and Rfe we could get :
Istart=V/sqrt((Xs+X'r)^2+(Rs+R'r)^2)
As the load is represented here by the slip, as we can see at start the slip is not involved in Istart formula. That means Istart does not depend on load.
Julius
02/22/2013 5:13 AM
link not working
pnaban
Good Answers: 42
02/22/2013 6:44 AM
Julius
02/22/2013 9:07 AM
thanks.
pnaban
03/30/2013 11:35 AM
Dear Mr. tigerdon,
The No Load Current will be 35 to 40 % of FULL LOAD CURRENT but Power Factor will be very LOW to the extent of 0.3 to 0.4.
For other details pl. Refer Standard Text Book of Elec.Engg - INDUCTION MOTOR - CIRCLE DIAGRAM, which will clear all your doubts.
DHAYANANDHAN.S
Register to Reply 10 comments
7anoter4 (3); Codemaster (1); dhayanandhan (1); JRaef (1); pnaban (3); redfred (1)
