Right now we are doing manual countersinking operation (2 nos) on a copper strip, we want to increase the o/p to 5000 no per shift i.e. 5 sec/job.
we are having following problems-
1) since the copper strip is just 2.5mm & 140mm long & with distinct profile, it is difficult to feed thru vibratory bowl feeder (5sec/job)
2) there are 2 c'sk operation to be done on each job. This can be done either by using indexing table with drilling head at two station (most preferrable but costly) or by using one head with job translating below the drill equal to pitch of the two holes (will take more time) or by using twin spindle drill head (may not be possible as the pitch is just 10mm & major dia of c'sk is 8.5mm).
Pls suggest a proper feeding & machining arrangement so that each job is accomplished in 5 sec
