Previous in Forum: Control Transformer   Next in Forum: Piezoelectricity
Thermal Magnetic Release in Circuit Breaker
02/25/2013 1:01 AM
In circuit breaker to operate thermal release Bi-metal is used to trip
In same manner what we are using in the magnetic release.
Pathfinder Tags: Thermal magnetic release..
New Zealand - Member - Kiwi
Good Answers: 29
Re: Thermal magnetic release in circuit breaker
02/25/2013 3:56 AM
A coil and armature.
paulusgnome
02/25/2013 7:16 AM
So IDMT relay is inbuilt in the circuit breakers?
Good Answers: 804
02/25/2013 6:18 PM
"So IDMT relay is inbuilt in the circuit breakers?"
No. In IMDT implies a delay, the magnetic trips in a Thermal-Magnetic circuit breaker are intended to be instantatneous.
It's a simple mechanism, basically the conductor path is coiled to product an inductor, and a metal plunger is fitted inside of the coil and held in place with a spring that has a specific amount of mechanical force. If the current increases slowly, the plunger barely moves because normal curent flow does not produce enough force in the plunger to overcome the spring force. But if there is a short circuit to where there is an extremely high and rapid increase in current, the plunger thrusts forward with enough force to overcome the spring and hit the trip mechanism.
There are of course, many variations of this theme.
Good Answers: 131
02/25/2013 8:02 AM
The magnetic trip is usually an instantaneous trip function for short circuit.
Register to Reply 4 comments
JRaef (1); Muthuvel (1); Paulusgnome (1); PeterT (1)
